FAQs: Integrating magicplan with Xactimate®
This FAQ aims to address common inquiries regarding the integration of magicplan with Xactimate®. Below you will find a table of contents categorizing the questions by type for your convenience.
General Questions
What devices can I use magicplan to create floor plans for Xactimate?
How long does it take for my sketch and photos ESX file to be ready?
Can I edit my floor plan or photos after exporting them to Xactimate?
Will the layout include the kitchen cabinets in the sketch when transferred to Xactimate?
Photo Management
Account and Subscription
What subscription do I need to export from magicplan to Xactimate?
How much does it cost the Xactimate integration with magicplan?
Setup and Compatibility
What devices can I use magicplan to create sketches for Xactimate®?
magicplan supports ESX sketch creation for Xactimate® on both iOS and Android devices. For optimal performance, make sure the app is updated to the latest version and that your device meets magicplan’s minimum requirements.
The file generation process is generally quick, taking a few minutes to seconds. Once the file is generated, you will be emailed a link.
How accurate are the floor plans created with magicplan?
magicplan helps restoration teams capture reliable floor plans on site for documentation, scoping, and estimating. LiDAR Auto-Scan provides a fast starting point on compatible iOS devices. For greater precision, connect a Bluetooth laser meter to verify and refine measurements directly in your floor plan.
Can I edit my sketch or photos after exporting them to Xactimate®?
Adjustments can be made within Xactimate®. For layout changes or photo edits, do so in magicplan and re-export the project.
Does the Sketch subscription include Xactimate®?
The Sketch subscription does not include the Xactimate® integration.
Are rooms missing from the 2D sketch?
Missing rooms in the 2D sketch indicate walls did not close properly during scanning. Close doors, use Manual-Scan for open plans, or add filler rooms as needed.
Will the layout include the kitchen cabinets in the sketch when transferred to Xactimate®?
Currently, kitchen cabinets are not included in the sketch layout transferred to Xactimate.
Is there a limit to how many photos I can include with my floor plan export?
While magicplan allows for extensive photo documentation, it's best practice to include only the most relevant photos to your claim, recommended to stay below 100MB in total.
This is because Xactimate® allows a maximum of 100MB of photo storage per project. If you exceed this limit, the transfer to Xactimate®️ will fail, and you will receive an error message.
To avoid this, you can enable photo compression for the ESX File, as shown in Step 2A.
If your photo file is still too large, you can download a zip file of your photos in magicplan and manually import them into Xactimate. See this article for instructions.
When I take pictures inside the rooms, will the photos show up in Xactimate® in the rooms where I took the photos?
Yes. We recommend labeling your photos in magicplan before exporting so they appear correctly in Xactimate®. To learn how to include photos in your ESX file, watch this video.
What subscription do I need to export from magicplan to Xactimate®?
magicplan's Xactimate® integration is automatically enabled for all PRO subscribers.
Do I have to have the magicplan account email the same as the Xactimate® account, or can it be different emails?
It is not required for the magicplan account email to match the Xactimate® account email, though ensuring both accounts are properly linked is crucial for seamless integration.
How much does it cost the Xactimate® integration with magicplan?
The Xactimate® integration is included in your magicplan PRO subscription at no extra cost and is automatically enabled for all PRO subscribers.
Do you offer a trial?
magicplan does offer trial periods for the Xactimate® integration. These trials allow you to test the features and see how they fit with your workflow before committing to a subscription.
Does magicplan also integrate with Symbility/CoreLogic?
Yes, magicplan integrates with Symbility (CoreLogic), but you'll need to activate the integration first in the magicplan Cloud. Once activated, you can download the FML files and photos from magicplan and send them to CoreLogic. For detailed instructions on how to activate and use this integration, please visit our dedicated help center page.
Xactimate® Integration setup - What do I need to do?
To set up the Xactimate® integration, ensure you have an active subscription that includes this feature, then follow the setup instructions provided by magicplan, which typically involve linking your Xactimate account within the magicplan app.
Does it include XactRemodel?
magicplan does not integrate with XactRemodel® at this time, focusing solely on Xactimate®.
Where can I find my XactNet address in Xactimate online?
Your XactNet address is a unique identifier for your account within a specific instance. There are two options for finding the address:
To find the address through Help:
1. Go to the project dashboard and select Help.
2. Choose About Xactimate® and look for the XactNet Address for your instance.To find the address through the account icon:
Click on the account icon when you have Xactimate® open to Local, Cloud, Preferences, or Tools.
For detailed instructions, visit the Xactware help documentation.
