Restoration Floor Plans: How to Sketch Complex Properties Faster
Not every restoration job is a collection of clean, rectangular rooms.
You walk into an open-concept property where the kitchen flows into the living room. There's a staircase in the middle, a storage room tucked behind the kitchen, closets in awkward places, and furniture blocking half the walls.
You still need to leave with a restoration floor plan the estimator can work from.
The answer isn't forcing every property through the same sketching method. A better field workflow gives technicians several ways to capture the structure, then lets them combine those methods into one usable floor plan.
1. Break Complex Properties Into Manageable Sections
An open floor plan doesn't have to be scanned in one pass.
For complex layouts, technicians can use LiDAR Auto Scan to capture logical sections separately and connect them afterward. In the example, the kitchen is scanned first, including cabinets, appliances, and a storage area. The adjoining living room is then captured as a separate scan with its stairs, furniture, doors, and windows.
This gives the technician a simpler task in the field.
Instead of trying to make one enormous scan understand every boundary perfectly, capture one area at a time and assemble the property afterward.
2. Give LiDAR Enough Context to Capture the Room
Good scanning technique still matters.
When possible, take a step back so the scanner has a complete view of the area. For smaller details or objects that aren't being recognized clearly, move closer and give the scanner another perspective.
The goal isn't to stand perfectly still and hope the technology figures everything out.
Move through the space deliberately and give it enough visual information to understand the property.
And if the first scan isn't perfect, don't throw it away. The room shape, objects, doors, and unnecessary walls can all be adjusted afterward.
3. Connect Separate Scans Into One Floor Plan
Once the main areas are captured, bring them together to reflect the actual property.
The kitchen and living room scans in the example are created independently and then assembled into the complete open-concept layout.
This is particularly useful for restoration contractors because the property doesn't need to fit neatly into one capture method.
The field technician can break the job into pieces that make sense while scanning, then connect those pieces into the structure the estimator needs.
That means less time fighting the layout on site and more time capturing what actually matters.
4. Treat Stairs and Closets as Their Own Problems
Stairways can make an otherwise simple floor plan complicated.
Rather than forcing them into the adjoining room, one option is to create the stairway as its own space and connect it directly to the appropriate room. The transcript demonstrates exactly this approach.
Smaller spaces can be handled differently.
For areas such as closets, filler rooms can be used to complete the floor plan without requiring another full scan.
That's the advantage of having more than one tool available.
Scan the spaces worth scanning. Build the spaces that are easier to build.
5. Clean Up the Sketch After the Main Capture
A field sketch doesn't have to emerge perfectly formed from the scan.
Once the main structure is there, technicians can adjust the room shape, reposition objects, correct doors, or remove walls that don't belong.
This is especially useful in real restoration environments where furniture, damage, containment, equipment, or limited access can interfere with a clean scan.
The important thing is leaving the property with enough information to produce a reliable record.
Capture the structure first. Clean up the exceptions second.
6. Switch to Manual Sketching When It Makes More Sense
LiDAR doesn't need to be the answer to every room.
If part of a property is easier to draw manually, technicians can add corner points to build the room themselves. A Bluetooth laser meter can then feed actual measurements into the sketch so the manually created section can be assembled with the rest of the floor plan.
This hybrid approach matters because no two losses look the same.
One room might be ideal for LiDAR. Another might be faster to draw. A closet may only need a filler room. A difficult dimension might be better captured with a laser.
The workflow should adapt to the property, not the other way around.
7. Why a Better Restoration Sketch Matters Beyond the Floor Plan
For restoration companies, the sketch isn't the final product.
It's the foundation for what happens next.
An accurate restoration floor plan gives the estimator spatial context for the scope. It helps show how affected rooms connect. It provides measurements that can support estimating. And it creates a structure where additional field documentation can stay connected to the property.
That's also why digital restoration sketching has become such a competitive category. Current tools increasingly emphasize scan-to-sketch workflows and moving captured property information directly toward Xactimate or other estimating systems rather than recreating the layout from scratch.
The value isn't simply drawing faster. It's giving the next person a better starting point.
8. Use the Right Capture Method for the Space in Front of You
Complex properties don't need complicated field workflows.
Break open spaces into manageable scans. Give LiDAR enough context to capture the room. Connect the sections afterward. Treat stairs and closets separately when that makes the sketch cleaner. And switch to manual drawing or Bluetooth laser measurements when they're the better tool for the job.
That's how a restoration technician turns a difficult property into a usable floor plan without spending the entire inspection fighting the sketch.
Capture what you can automatically. Adjust what needs attention. Measure what matters. Then give the office a restoration floor plan they can actually work from.
