How to Dump Extracted Water Correctly (A Guide for Restorers)
When you’re running a water job and pulling gallons of nasty water out of a structure, one question always comes up: “Where the heck can I dump this stuff?” We hear it all the time. And here’s the hard truth:
There’s no one-size-fits-all rule. But there is one right answer:
✅ Follow your local laws - That’s it. That’s the rule.
Is Your Water Disposal Method Legal?
Different states. Different counties. Different zip codes.
What’s totally legal in one neighborhood might get you fined two blocks over.
You might be allowed to use a cleanout in the yard in one town. Drive 10 minutes, and you’re required to take it to a wastewater facility.
The kicker? Dump it wrong — especially Category 3 water or anything grossly contaminated — and you could do more than eat a fine. You could lose your license.
Ask These Questions Before You Dump
To stay out of trouble, start with the following checks:
What’s in the water?
Is it clean (Cat 1), contaminated (Cat 2), or nasty (Cat 3)? Raw sewage? Gray water?
Your disposal plan depends on the answer. Not sure about the category? Take a look at this link: Water Categories and Classes Explained
Is it safe to send down a drain?
Don’t guess. And don’t assume it’s fine just because someone else did it before.Who’s the AHJ?
That’s Authority Having Jurisdiction. Could be the city, the county, or even a local health department. Find out who they are — and what they allow.Where’s the disposal site?
If they say “take it to a facility” go there. If they allow cleanouts, document that and stick to it.
Are you tracking and training your crew?Don’t leave this to chance. Every tech on your team should know the rules and follow the same protocol.
“We’ve Always Done It This Way”
🚫That’s not a plan — that’s a liability.
We’ve seen teams get burned because someone dumped water in a “usual spot” and a neighbor called it in. If it's not documented and approved by your AHJ, you're exposed.
And remember: Category 3 water isn’t just gross. It's regulated differently in many areas. The moment you're dealing with black water, you’re in a different legal zone.
Here’s What to Do Right Away
Call your local AHJ
Ask directly: “What’s the legal method for disposing of water extracted from a restoration job in (city/area)?”Write it down
Create a one-pager for your team: What to do, where to go, who to call.Train your crew
Make it part of your onboarding. Review it during weekly meetings. Everyone should know the cold disposal plan.Label the extracted water
Note category type and volume — especially if you’re tracking for large losses or multi-day jobs.
Review your liability insuranceMake sure improper disposal isn’t an exclusion. If it is, get that fixed.
Include magicplan In Your Scope
With magicplan, you can create the perfect form so your on-site technician can instantly capture all essential information — including photos, notes, videos, and more. Everything is shared immediately with your office team, ensuring a structured, faster, and highly accurate workflow. You can find more info here → How to Create & Use Forms.
