How to Capture Moisture Data Faster by Integrating Tramex and magicplan
If you’re still snapping pictures of your moisture meter and manually typing readings into your job file, you’re spending time you don’t need to. That’s now over — magicplan just made it automatic.
Real‑Time Moisture Readings, Logged Instantly
Thanks to Bluetooth integration, Tramex moisture meters can now connect directly to magicplan. That means you can place a moisture point on your floor plan, tap once to take a reading, and boom — it’s logged in the right spot, automatically.
✅ No flipping between apps.
✅ No scribbling on notepads.
✅ No later guessing which photo went with which room.
Here’s How It Works in the Field
→ In the magicplan app, drop a moisture meter object on your floor plan.
→ Tap “Use Readings”
→ Your connected Tramex pulls in the real‑time reading via Bluetooth and logs it on the spot. As you can see here from the screenshot.
→ Need a photo to back it up? Snap it right there — it’s timestamped and linked to the exact data point.
This works whether you’re testing subfloors, drywall, or cabinetry. Everything’s saved, sorted, and ready to go — without any extra steps.
Compatible Tramex Meters
🔹Tramex ME5 (yes, even the classic analog model with Bluetooth)
🔹CMEX5 and other Tramex Bluetooth‑enabled meters
Why is this a game changer?
Contractors and estimators deal with constant pressure to prove accuracy — especially when adjusters push back. This integration means no more “he said, she said” Every reading is tied to a place and time, with proof baked in.
You finish a job with a complete, exportable moisture log. Send it off as a labeled, clean PDF to the carrier, client, or estimator. It’s clarity that speeds up claims and limits friction.
This Update is a time‑saver. Fewer steps in the field. Cleaner documentation. Faster claims. And one more reason restoration pros are leaning on magicplan to tie it all together.
You might also be interested in:
📘How to Document Moisture Points Like a Pro (and Skip the Rework)
📘How to Choose the Right Moisture Meter for Restoration Work
