Top 6 Benefits of Using Electrical Reports in Remodeling Projects
Whenever you are hired to complete a new project, it’s important to give thoughtful consideration to any needed electrical work. Of course, you already do this, right? But do you also visually document that electrical work before the project begins?
If not, you’ll find this brief guide to be helpful. Read on to learn the definition of ‘visual electrical documentation’ and discover six reasons why you should create it for every new project.
What Is Electrical Visual Documentation?
It is a floor plan drawn to scale, with all electrical details defined through the use of symbols and annotations. So, essentially, it is a visual representation – or blueprint – of the entire electrical system for a room that will be renovated. (This is different from a more expansive, whole house electrical plan, which is used for new construction.)
However, before you create this type of documentation, you will first want to complete a few other important steps:
develop a master plan for the overall project
assess the existing electrical system
check local codes
This orderly approach will help you prepare for any electrical work that must be completed.
Reasons for Creating Visual Electrical Documentation
The Easiest, Fastest Way to Visually Document an Electrical Plan
Simply do what many other remodeling and restoration experts do: use a digital floor plan app loaded onto a mobile device! A powerful and handy app will allow you to:
quickly measure and sketch a room
manipulate and refine the sketch to create the master plan you envision for the project
create a copy of that plan, and then add objects and notations to specify your proposed electrical layout
Be sure to look for a floor plan app that has an “electrical object library” – i.e., a built-in menu of predefined electrical symbols. These tools will simplify and speed up your creation of new visual documentation.
After your electrical plan is completed, study it as you walk through the space you will be renovating to make sure you didn’t overlook anything. Imagine you are flipping switches, turning on a fan, using appliances – doing anything that will require electricity. Also, ask yourself some questions: Did I place switches in convenient locations? Will the fan be positioned correctly? Will the homeowner be able to use all major and small appliances? Did I calculate the electrical load correctly, so that I’m not overloading the circuits? Does my plan meet all electrical codes?
If you identify any concerns, you can alter your digital sketch quickly, on the spot, to update it.
Creating visual documentation of an electrical plan benefits both you and your customer. Plus, it’s easy and fast to do with a digital floor plan app. So, vow right now to make it a part of every new project.
