Document moisture and drying progress
Keep track of your water mitigation efforts from start to finish.
Document the drying process
Map out moisture accurately and keep detailed logs as you dry.
Optimize drying setups
Calculate drying chamber dimensions to ensure optimal job setup and compliance with industry standards.
Document equipment
Log every piece of equipment from dehumidifiers to air movers. Manage usage, location, and deployment times to simplify billing.
Oversee jobs from anywhere
Stay in control, even when you’re off-site. Share updates, receive feedback, and keep your team, adjusters, clients, and others informed.Set up SOPs for your drying processes
No matter the job size, ensure every task is done right and documented thoroughly.
Get the full story on every job
- VISUAL DOCUMENTATION
- SITE ASSESSMENT & SCOPE OF WORK
- DRY LOGS & MOISTURE READINGS
Bdrgn
08/24/2023
QueenMcGhee
03/27/2023
TAHA ALBASEER
01/27/2024
Best app so far
