LiDAR Floor Plans: How to Scan Complex Open Spaces Faster
Open-concept properties can make restoration sketching harder than it needs to be.
The kitchen flows into the living room. A staircase breaks up the space. There's a small closet tucked into one corner. And your technician still needs to leave the property with a floor plan the office can actually use.
Instead of trying to draw the entire layout manually, a LiDAR floor plan lets you capture the space while walking through it, then clean up the details afterward.
The goal isn't to create a perfect scan in one pass. It's to capture the property quickly while you're standing in it and turn that field information into a usable job record.
Steps to Create a LiDAR Floor Plan for Complex Open Spaces
Why LiDAR Floor Plans Matter for Restoration Work
For restoration contractors, creating a floor plan isn't an isolated drafting exercise.
That sketch becomes context for the rest of the job.
It helps the office understand how rooms connect. It gives estimators measurements and spatial context. It provides a place to organize affected areas and other field documentation. And it gives reconstruction a record of the property that was captured while the crew was actually standing in it.
The faster technicians can create that record without sacrificing useful detail, the less information the office has to rebuild later.
Make the Floor Plan Usable, Not Perfect
The best field sketch isn't necessarily the one a technician spent the longest creating.
It's the one the rest of the team can use.
With LiDAR Auto-Scan, complex areas can be captured section by section, adjusted after scanning, and assembled into one floor plan. Stairs can be repositioned, walls corrected, and smaller spaces added without rebuilding the entire sketch.
That means less time fighting with the layout on site and more confidence that the information captured in the field can keep moving with the job.
Scan what you see. Fix what needs fixing. Leave the property with a floor plan the office can work from.
READ MORE: How to Migrate from DocuSketch to magicplan (A Step-by-Step Guide)
