How restoration contractors can automate the busywork around magicplan using viaSocket
magicplan automations for restoration contractos using viaSocket with logos from Jobnimbus, housecall pro, google calendar, google drice, airtable, quickbooks and  xero
magicplan connects to viaSocket, a no-code automation tool (think Zapier), which links it to the apps you already run: QuickBooks, Xero, JobNimbus, Housecall Pro, Google Calendar, and customer texts through Twilio. When a job is created or updated in magicplan, viaSocket can text the homeowner, create the job in your CRM, draft the invoice, or schedule the inspection. Nobody re-types a thing.
Your tech wraps a job and heads to the next call. Then the copy-paste tax kicks in. Someone opens the CRM and re-enters the customer. Someone texts the homeowner to say you're on the way. Someone updates the job tracker. Someone starts the invoice in QuickBooks. Same information, keyed in four times, by four people. And if one of them is out that day, it just doesn't happen.
That's not a magicplan problem. It's the gap between magicplan and the other apps you run. Here's how to close it without hiring anybody.
What is viaSocket, and how does it connect to magicplan?
viaSocket is a no-code automation platform. You build a "flow" that says "when this happens in one app, do that in another," and it runs in the background on its own. magicplan has a connector on viaSocket, so magicplan can be the app that starts a flow, or the app a flow updates. From there, viaSocket reaches 2,300+ other tools. You don't write code. You pick a trigger, pick an action, map a few fields and turn it on.
Learn more about magicplan integrations.
What can magicplan trigger and do through viaSocket?
Worth being straight about what's actually available today, so you build flows that work instead of ones you wish existed.
Two triggers, both at the whole-project level. Build your flows around job events (a job comes in, a job gets updated), not individual field changes.
6 automations you can set up this week
  1. Text the homeowner the minute the job's booked. When a new project is created in magicplan, viaSocket sends the customer a text through Twilio: you're on the schedule, here's what happens next, here's who to call. The person whose house just flooded is stressed. A text in the first hour does more for your reviews than anything on the truck.
  2. Create the job in your CRM or job-management tool. Same trigger, push the customer, address and loss type into JobNimbus or Housecall Pro so the office isn't re-typing what the tech already entered on site.
  3. Put the inspection on the calendar. A new project in magicplan adds the site visit to Google Calendar, so dispatch sees it without a phone call.
  4. Spin up the job folder. A new project creates a Google Drive folder named for the address, so every form and PDF has a home from minute one.
  5. Keep the WIP board live. When a project is created or updated, append a row to a Google Sheet or Airtable tracker. Your Monday numbers come off live jobs, not someone's memory.
  6. Draft the invoice when the capture's in. When a project updates, create a draft invoice or estimate in QuickBooks or Xero so billing isn't waiting on a handoff email.
You can also run it the other way. When a lead comes in through a web form or Facebook Lead Ads, have viaSocket create the project in magicplan so the job's ready before the truck rolls.
Where this fits, and where it doesn't
Real talk: viaSocket automates the handoffs between apps. It's not a replacement for magicplan's built-in exports. Your ESX file into Xactimate still comes straight out of magicplan, no automation tool needed. And the triggers today are project-level (created and updated), so flows fire on whole-job events, not on a single measurement changing. If you need something more specific, viaSocket lets you request new triggers, and it's worth asking for.
The goal isn't to automate everything. It's to kill the three or four copy-paste steps that eat your office's day and quietly go missing when someone's out sick.
How to get started
  1. Create a free viaSocket account.
  2. Start a new flow and search magicplan for your trigger.
  3. Pick the app on the other end (QuickBooks, your CRM, Twilio).
  4. Map the fields once: project name, address, customer, phone.
  5. Turn it on and run a test job through it.
Start with one flow. The text-the-homeowner one takes about ten minutes and your customers feel it the same day.
FAQ
Does magicplan integrate with Zapier?
magicplan connects through viaSocket, a Zapier-style no-code automation platform, which bridges it to 2,300+ apps including QuickBooks, JobNimbus, Housecall Pro and Twilio.
What can trigger a magicplan automation?
Two events today: a new project is created, or a project is updated.
Can I text customers automatically when a job comes in?
Yes. A viaSocket flow can send the homeowner a text through Twilio the moment a new project is created in magicplan.
Do I need to know how to code?
No. viaSocket is no-code. You pick a trigger and an action, map a few fields and turn it on.
Next step: See how the field record your crew captures flows through the rest of your business.
How to get started
FAQ
