How Restoration Teams Keep Every Job File in One Place
The technician has photos on a phone. The signed form is in the truck. A contract arrived by email. The sketch is in one app, the report is in another, and the invoice is somewhere in a text thread. By the time the office starts building the estimate, the people who understood the loss best are already standing in the next one.
Then the questions begin.
Which photo belongs to the basement? Is this the latest report? Did anyone scan the signed document? Where is the original PDF? What did the technician mean by that note?
This is not just untidy paperwork. It slows estimating, creates callbacks, weakens the documentation package, and makes the owner the person who has to find what everyone else missed. When mitigation hands the job to reconstruction, the context can disappear all over again.
A practical construction document management system should stop that chain at the source. The crew captures the job once, while they are there, and the files stay connected to that project as the work moves from mitigation through the rebuild.
What is document management?
It means keeping the documents for a project organized, current, accessible, and tied to the work they describe. For a restoration contractor, the job file may include:
floor plan and statistics PDFs
photo reports and 360-degree documentation
contracts, authorizations, and signed forms
estimates, invoices, receipts, and purchase records
permits, specifications, and supporting documents
water, fire, mold, or CAT loss reports
annotated PDFs that highlight affected areas or scope details
The objective is not to collect more files. It is to make the right information easy to find and use. A folder full of unexplained documents still leaves the estimator decoding the field. Useful documentation keeps the evidence in context, connected to the property and the job.
Why scattered job files cost restoration teams time and money
Every missing or disconnected document creates work somewhere else.
The technician gets pulled back into a finished job
The field technician wants to leave the site done, not “mostly done.” If paperwork is captured later, the technician has homework at the shop or gets a call while working another loss. If a signed form or photo cannot be found, someone may have to return to the property.
The estimator becomes a detective
The office does not need another pile of photos or PDFs to decode. It needs the rooms, measurements, evidence, and job documents in a structure that makes sense. When the field file is thin or scattered, the estimator spends time chasing answers instead of pricing the job and getting the file out.
The owner stays trapped as the safety net
Inconsistent files force the owner to keep checking behind the team. That may be manageable with a few jobs, but it breaks under growth or a CAT event. A company cannot run consistently if every project depends on one person knowing where the missing document went.
Reconstruction starts over
Mitigation and reconstruction are two phases of the same job. If the initial contracts, reports, photos, and floor plan do not carry forward in a usable record, the reconstruction team repeats work that has already been done. That is where context and margin quietly leak out.
How the magicplan Files section works
The Files section is the central place for documents connected to a magicplan project. It includes files generated in magicplan and documents imported from outside the app. That means a floor plan report can live beside an uploaded contract, a scanned paper form, a photo report, and an edited PDF. Instead of checking a filing cabinet, email, camera roll, and several apps, the team can start with the project. For the current list of supported file types and step-by-step instructions, see magicplan’s Files section guide.
How do you generate a project file in magicplan?
The updated interface looks different, but the familiar export workflow remains straightforward.
Open the project and go to the relevant floor plan or photo section.
Open Files and Sharing from the upper-right menu.
Choose the file you want to generate, such as a statistics report.
Wait for magicplan to create the file and open its preview.
Return to the project’s Files section to find the generated
document.
Floor plan exports appear with the files related to the floor plan. Photo reports appear with the files created from project photos. Filters can help narrow the list by file type, including PDF. magicplan supports several project export types. Review the current options in magicplan’s export formats guide or learn how to export and share projects.
How do you upload an existing document?
If the document is already stored on your phone or tablet, you can add the digital copy directly to the project:
Open the project’s Files section.
Select the option to upload a file.
Browse the files stored on your device.
Select the document or documents you need.
Confirm the upload and check that each file appears in the project.
Rename the file clearly if the original filename will not make sense
to the rest of the team.
Use filenames another person can understand without opening the
document. A practical pattern is: Job address - document type - date - status
For example: 125 Oak St - Work Authorization - 2026-08-10 - Signed.pdf
Clear naming reduces the chance that the estimator prices from an outdated report or sends the wrong document to a carrier or customer.
How do you scan paper documents into a project?
If the crew receives a physical document, it can be digitized without waiting to return to the office.
Choose Scan Document.
Hold the device over the page until the app identifies it.
Capture the document and preview the scan.
Crop or adjust the page if needed.
Save the scanned PDF.
Rename it so the office immediately knows what it is.
This is especially useful for signed forms, printed work authorizations, receipts, permits, or other paperwork that might otherwise stay in a truck or become separated from the job. Before leaving, open the scanned file and confirm that every page is present, readable, correctly oriented, and attached to the right project. A blurry scan is not complete documentation
Edit and reorganize a PDF report
Not every recipient needs every page of a comprehensive report. The document editor allows you to create a version suited to the audience without losing the original. In the PDF editor, you can:
rearrange pages
select and delete pages that are not needed
remove individual content elements
update text, such as a project name
move or resize elements such as a logo
save the result as a newly named file
A strong version-control habit is to keep both the unedited file and the edited copy. Give the revision a descriptive name rather than “edited PDF 2.”
For example: 125 Oak St - Carrier Report - 2026-08-10 - Revised.pdf
The original gives your team a clean source to return to. The revised copy makes it clear which version was prepared for a particular purpose.
A five-minute job-file check before the technician leaves
Before closing the site visit, ask:
Are the signed forms scanned and readable?
Are contracts, permits, invoices, and receipts attached to the correct project?
Have the floor plan and photo reports been generated?
Are important conditions marked directly on the relevant PDF or image?
Is the original document preserved alongside any edited version?
Could an estimator who never visited the property understand the file without calling?
Will the reconstruction team be able to build from this record later?
The final two questions are the real standard. Good construction document management is not about making the Files section look tidy. It is about making the field record usable after the people who saw the loss have moved on.
What does better file management change day to day?
For the technician: no paperwork hanging over the day
Scan the signed document while it is in your hand. Add the clarification while the condition is in front of you. Save the report to the job. When you leave the site, the documentation leaves finished with you.
For the estimator: less chasing, more estimating
The estimator opens the project and finds the floor plan, photos, reports, contracts, and supporting documents together. The work becomes reviewing and pricing, not searching across emails or asking the field to recreate context.
For more on that handoff, read how estimators can get better field documentation from technicians.
For the owner: consistency without checking every file
A repeatable file workflow gives the team a shared standard. One technician should not submit a neat digital record while another hands the office paper and mystery filenames. Consistency reduces the number of gaps the owner must personally catch and helps the business run the same way on its busiest week. For mitigation and reconstruction: one job record Contracts, reports, photos, estimates, and supporting documents should not stop at the mitigation handoff. Keeping them with the project gives reconstruction something real to build from instead of another blank page.
Explore the restoration workflow guide for a broader look at carrying field information through the job.
Keep the proof with the job before anyone asks for it
The best time to organize a restoration file is not when an adjuster questions the scope or an invoice comes back. It is while the crew is still standing in the loss and the documents are already in their hands.
magicplan brings generated files, uploaded documents, scanned paperwork, and editable PDFs into the project. The technician captures the record at the source. The office works from information it can use. Reconstruction keeps the context mitigation collected. And the owner spends less time chasing jobs that should already be moving.
Frequently asked questions
What is a construction document management system?
A construction document management system is a structured way to create, store, organize, revise, and share project documents. For restoration work, it should keep field records connected to the property and make them usable by technicians, estimators, project managers, owners, carriers, and reconstruction crews. What files should a restoration project include? The exact documents depend on the job, but common examples include floor plans, photo reports, contracts, work authorizations, estimates, invoices, permits, receipts, forms, moisture or damage reports, and annotated PDFs.
Can I upload documents to magicplan?
Yes. The project’s Files section supports several common document formats. Check the current Files section documentation for the supported formats and upload steps. Can I scan paper documents with magicplan? Yes. Use Scan Document to capture a physical page, preview and crop it, save it as a PDF, and rename it inside the project.
Can I edit PDFs in magicplan?
Yes. You can annotate PDFs, add text and images, rearrange or delete pages, remove content, update text, and save an edited copy. Available tools can depend on the file and app version.
Should I keep the original PDF after editing it?
Yes. Keeping the original and a clearly named edited version gives the team a source file to return to and reduces confusion about which document was changed or shared.
How does file management help an insurance claim?
Organized files make it easier to find the photos, measurements, reports, signed forms, and annotations that support the scope. The objective is to have the proof in the project before a carrier, TPA, customer, or estimator asks for it.
READ MORE: Get Paid Faster: Why Good Documentation is Key in Restoration Projects
Leiter Vertriebsakquise
