How Poor Documentation Wrecks Your Restoration Company Margins
If you’re like most restoration contractors, you know the frustration of doing the hard work… only to fight for every dollar you’re owed. You might be moving fast, juggling multiple jobs, and trusting your field teams to capture what’s needed. But here’s the hard truth: The number one reason your company is not getting paid for all completed work could very likely be poor field documentation. If you want to restore healthy profit margins and get paid for every bit of value your company delivers, fixing your field documentation process is the single most impactful move you can make.
The Cost of Incomplete Field Documentation
Incomplete field documentation is one of the biggest obstacles in the restoration estimating process.
When your field team fails to capture detailed, accurate records when scoping new job sites, it creates uncertainty and gaps that ripple through every stage of your estimates. Office-based estimators are left to guess or make assumptions about the extent of work that is needed, which often leads to conservative estimates that leave out legitimate line items and explicit details.
Ultimately, incomplete documentation undermines your ability to build comprehensive, defensible estimates for both residential and commercial restoration services. The result is lower approved values, more disputes with adjusters, and a longer, more frustrating payment process — all of which erode your company’s profit margins.
But you don’t have to let that happen: Some industry experts state that restoration estimates supported with sufficient, high-quality documentation can generate around 20% more income than comparable estimates based on poor documentation.
That can be the difference between a struggling business and a thriving one.
Common Mistakes To Watch Out For
If you want to stop the margin bleed, start by spotting the weak documentation habits that are costing your company.
1. Photo Overload: The Wrong Kind of Evidence
A common mistake is thinking that more photos equal better documentation. Field teams often capture large quantities of the wrong photos. For example, snapping dozens of shots of a single moisture meter reading is overkill. While the intent is good, this approach doesn’t help your estimate. Adjusters and estimators need clear, relevant evidence: wide shots of the room, close-ups of the damage, before-and-after comparisons, single shots of instrument readings, and images that show the context of the work performed.
2. The Margin-Killing Gap: What Gets Done vs. What Gets Written
The most dangerous documentation habit is assuming someone else will fill in the blanks. For example, when field techs don’t capture exactly what kind of emergency-mitigation work was done, in sufficient detail, the estimating department is left making guesses or fighting uphill battles with adjusters. Vague notes like “treated for mold” or “removed wet carpet” don’t stand up to scrutiny. The result? Line items get cut, work goes unpaid, and your company’s profit margins shrink with every job.
3. Other Red Flags That Indicate Inadequate Scopes
Inadequate (or no ) sketches of damaged-affected areas at job sites
Not enough photos demonstrating the type and extent of damage found
Vague descriptions in notes (e.g., “drywall removed” instead of “removed and disposed 200 sq ft of water-damaged drywall in living room”)
Missing before-and-after shots
No visual evidence (photos/videos) of mitigation equipment placement or readings
Inconsistent terminology or incomplete forms
Documentation that varies wildly from one team member to another
If any of these sound familiar, you’re not alone — but you’re also not stuck. The solution is a combination of standardization, training, and the right documentation tool.
How to Fix Your Documentation Process
Standardize What “Good” Looks Like
Create a repeatable documentation process. Develop checklists and templates for your team to follow when scoping every new job. Specify the types of photos needed (wide room, close-up of damage, equipment in use, before/after, etc.).Train and Audit Regularly
Don’t assume your team knows what’s required. Train them on what good documentation looks like, and audit their work regularly. Give feedback and show examples of both strong and weak documentation.Use Technology to Capture What Matters
A modern documentation app can make this process much easier, but only if field technicians use the tool to its full potential. For example: Not just taking more photos, but taking the right ones, and organizing everything in a way that tells the complete story of the job.
A Good Documentation App Can Make All the Difference
A restoration software tool such as magicplan Pro Estimate can help transform your margins. This professional-grade app allows your technicians to build scopes quickly and cleanly, thanks to these key features:
Smart visual documentation: magicplan enables them to create accurate room sketches and also capture the types of photos and videos that matter to adjusters and estimators.
360° virtual tours: One of these tours can show more useful detail than 20 random close-ups, giving reviewers a true sense of the affected space and the extent of the loss.
Built-in forms: Custom forms help field techs document observed damage and as well as initial mitigation work, including antimicrobial treatments, contents moved, demoed materials, and more. This ensures nothing gets missed or left vague.
Standardization: By building repeatable workflows into your team (with templates, checklists, and required fields), you don’t leave documentation up to chance. Everyone captures the same critical information, every time.
Xactimate & CoreLogic Integration: Field techs can export ESX or FML files directly from their project scopes to save time and avoid duplication of effort, ensuring your documentation flows seamlessly into your estimating.
The Bottom Line: Proper Documentation Is Your Key to Better Margins
If your company performs any type of restoration work, such as water damage restoration or fire damage restoration, it’s not enough to work hard and hope for the best. Your documentation also plays a key role in driving your profitability. When you improve your documentation process, your restoration business doesn’t just get paid faster — it gets paid more. That’s because proper documentation helps to generate estimates that produce fair compensation.
So, if you want to stop leaving money on the table, start by making some changes.
Make high-quality scoping a core part of your company culture: Standardize your scoping process. Train your team to use it. And equip them with an effective documentation app. These changes will make it easier for your team to capture what matters most, so you can finally restore your company’s profit margins to where they belong.
Could You Also Benefit from Some Estimating Support?
Maybe you’re bringing in more business than your estimator can handle. Or maybe you’re currently without an in-house estimator. Either way, here’s a helpful approach to consider: Let your field techs use the magicplan Pro Estimate+ (Powered by Epic Estimates) to scope new jobs, and then let us create the estimates. You can send any scope to magicplan and get a ready-to-go, carrier-compliant restoration or mitigation estimate for insurance claim purposes – one that’s built by an expert using Cotality estimate software or Verisk Xactimate software. Schedule a call with our sales team today to learn more about this unique service.
