Staircase Floor Plan: Add Stairs in Under 2 Minutes
You know the scene. You have already walked the loss, captured the rooms, taken the photos, and started thinking about the next stop. Then the staircase in the sketch does not look right. It is tempting to leave it for the office. But a small gap in the field rarely stays small.
The estimator opens the file and tries to work out where the stairs begin, how the floors connect, or whether the dimensions are reliable. A text or phone call follows. In the worst case, someone drives back to a job the crew already finished.
When reconstruction starts, the same property may be measured again. Stairs are important structural elements, but they can also be difficult for a mobile scanner to capture perfectly. The fix is not another pile of photos or a full rescan.
With the magicplan floor plan app, the person standing in the property can add the right staircase object, correct it on the spot, and leave the job with the sketch done, not “mostly done.”
Why getting the staircase right on site matters
For a restoration team, a staircase is not just a symbol on a drawing. It is part of the field record that the estimate, carrier conversation, mitigation work, and rebuild may depend on.
Getting it right before the crew leaves helps prevent four familiar problems:
A callback to the technician: The office should not have to ask what a photo or handwritten note meant after the technician has moved on to another loss.
A drive-back to remeasure: The crew can check and correct the staircase while the property is still in front of them.
An estimator rebuilding the sketch: Clean room geometry, measurements, and floor connections give the estimator something usable instead of another file to decode.
A weak mitigation-to-reconstruction handoff: The rebuild team can work from the same property record instead of starting again from a blank page.
The principle is simple: scan it quickly, fix whatever is off on the spot, and leave it done.
How do you add stairs to a floor plan in magicplan?
Adding a staircase follows the same basic workflow as adding other
objects from the magicplan object library.
Open the room. In your project, select the floor and tap the room where the staircase belongs.
Open the object menu. Tap + Add, then select Object.
Choose the structural category. Open Structural to see the available staircase objects.
Select a staircase. Choose the object that most closely matches the staircase at the property.
Position the stairs. Drag the staircase into the correct location and rotate it to match the direction of travel.
Adjust its size. Use your fingertips to reshape the object, or enter measurements in the object information panel.
Review it before leaving. Check the staircase in the 2D floor plan and, when helpful, inspect the automatically rendered 3D view. Make sure someone who was not on site can understand it
without calling you.
For the current in-app workflow and staircase options, see magicplan’s guide to using stairs to connect two floor levels.
Why might you need to adjust stairs after a LiDAR scan?
LiDAR makes property capture faster by detecting room geometry and common elements while you move through a space. However, staircases combine changes in height, open areas, railings, landings,
and repeating treads. Equipment, partial demolition, poor light, and the realities of a working loss can make the space harder to capture than an intact room.
If the staircase does not appear exactly as expected after scanning, treat the scan as the fast first pass. Add or adjust the staircase object in the editor instead of repeating the entire room capture. Accuracy comes from the person who saw the job checking and correcting the result before leaving, not from assuming every scan is perfect.
On a compatible iOS device, magicplan’s LiDAR Auto-Scan can capture multiple rooms and detect walls, doors, windows, furniture, and structural objects during one session. The LiDAR & Auto-Scan FAQ also explains current requirements and limitations.
How to connect stairs between two floor levels
For a clear multilevel floor plan, the staircase should be represented on each floor it connects.
Add the correct floor levels to the project.
Place a staircase object on the lower floor.
Add the corresponding staircase on the upper floor.
Position and rotate the objects so the staircase openings align.
Confirm the result in both 2D and 3D views.
This gives the estimator, carrier, project manager, and reconstruction
crew a clearer understanding of how the levels connect. More
importantly, it keeps the second phase of the job from becoming a
second documentation project.
What should a restoration technician capture at the staircase?
A staircase floor plan is more useful when the symbol is supported by the right visual evidence and field information. The goal is not to dump more photos into the file. It is to capture the details that explain the loss and support the work. Consider adding:
a wide photo showing the full stair run
photos of the top and bottom landings
close-ups of the water line, smoke or fire damage, mold, demolition limits, or other visible conditions
notes about finish materials, access constraints, affected assemblies, or observed conditions
relevant dimensions
a 360-degree image when spatial context is important
Add photos before, during, or after scanning. You can also annotate images to point out the exact location of damage or a required action. Tie the evidence to the relevant room or object so the estimator does not have to search through a camera roll and guess what each image proves.
For more ideas, read this guide to creating a floor plan with furniture, notes, objects, and photos. Restoration teams can also use annotations and visual documentation to identify damaged or affected areas.
The 60-second “no drive-back” check
Before leaving the property, review the staircase and ask:
Is it on the correct floor or floors?
Does its position match the room?
Is the direction of travel clear?
Do the objects align between levels?
Does the footprint reflect the measurements taken on site?
Are important landings, openings, or visible conditions documented?
Have you attached the photos and notes the estimator, carrier, or rebuild crew will need later?
Could a person who never visited the property understand what you captured?
This short check can prevent the familiar text from the office two days later: “What did you mean here?” It also gives the estimator a cleaner starting point and keeps the reconstruction crew from measuring the same house again.
Capture it once and carry it through the job
A useful floor plan does more than show walls. It carries what the crew knew on site to the people who were not there. When the staircase, measurements, photos, and observed conditions stay together, the office can build from what happened instead of guessing.
magicplan lets restoration teams create a floor plan, add structural objects, capture photos and videos, annotate damage, and keep project documentation together from the first visit onward.
Explore the complete restoration workflow guide, see magicplan’s Sketch tools, or follow the guide to creating your first floor plan.
Frequently asked questions about staircase floor plans
What is a staircase floor plan?
A staircase floor plan is a 2D drawing that shows the location, footprint, configuration, and direction of stairs within a building. In a multilevel plan, the stair symbols help explain how the floors connect.
How do you show stairs on a floor plan?
Use a staircase symbol that matches the real configuration as closely as possible. Position and rotate it correctly, adjust its footprint to the site measurements, and make the direction of travel clear.
Can LiDAR scan stairs automatically?
LiDAR can capture room geometry and may detect structural elements, but stairs can be challenging because they include multiple heights, openings, landings, and railings. Review the generated floor plan and add or adjust the staircase object when needed.
Where are staircase objects in magicplan?
Open the room, tap + Add, select Object, and choose the Structural category. Select the staircase that best represents the property, then place and resize it.
How do I add stairs between two floors in magicplan?
Add a staircase object to each connected floor, then align their positions and orientations. Review both levels and use the 3D view to confirm the relationship.
Can I add photos and notes to a staircase?
Yes. magicplan lets you add details and visual documentation to projects, floors, rooms, walls, and objects. Attach relevant photos and notes so reviewers can understand the staircase and any observed conditions.
Why should I fix the staircase before leaving the job?
Correcting it on site prevents the office from guessing, reduces callbacks and drive-backs, gives the estimator a more usable sketch, and preserves context for the reconstruction team. The person standing in the property is in the best position to verify what is right.
Silvia Corvi
Community Manager
