Bluetooth Laser Distance Measurer Buying Guide
A Bluetooth laser measure device can be valuable for anyone who needs to collect measurements on a regular basis. Compared to a metal measuring tape, this high-tech tool is faster, easier and more accurate to use, making it a much better choice. Plus, the Bluetooth connectivity means you can easily transfer measurements to your smartphone or tablet. But the cost is quite a bit higher than that of a traditional measuring tape. So, you’ll want to select a device carefully by considering three factors: (1) the price you’re willing to spend, (2) the software compatibility you need, and (3) the specific features you want.
Factor #1: The Price You’re Willing to Spend
Is price often a deciding factor when you’re shopping for tools and equipment? We get it. Sometimes your cash flow is too tight to accommodate an expensive gadget. On the other hand, you may feel comfortable spending more if you know you can get a higher-quality product with more bells and whistles. Either way, we’re here to help. Below, we list some Bluetooth laser measure devices that fall into three different price ranges. (Prices shown are approximate; actual prices may vary among retailers).
Entry-level: Under $200
Devices that typically fall into this most-affordable range include:
Bosch GLM 165-27 C Professional ($60)
Bosch GLM 50 CX 113 ($113)
Bosch PLR 50 C ($119)
Stabila LD250 BT ($140)
Leica Disto D110 ($165)
Leica Disto D2 ($165)
Bosch GLM 50-27 C Professional ($169)
Bosch GLM 165-27 CG Professional ($168)
Medium-range: $250-$450
Devices in this category include:
Leica Disto X3 ($268)
Leica Disto X4 ($329)
Bosch GLM 120 C / GLM 400 CL ($330)
Leica Disto D510 ($429)
High-end: $550-$750
These premium devices include:
Stabila LD520 ($573)
Leica Disto D810 ($739)
These options obviously cover a wide range of price points, which means you’re sure to find one that fits your budget. But before you select one to purchase, you’ll want to make sure it’s compatible with specific software that you use. So, let’s move on to that topic…
Factor #2: The Software Compatibility You Need
Bluetooth laser distance measurers are typically compatible with a wide range of software applications. Those include mobile apps and desktop software.
Mobile Apps
Certain apps allow users to connect to their measuring device via Bluetooth, to automatically capture and use measurements. For example, magicplan is a Bluetooth laser measure app that works seamlessly with several measuring devices, to enable fast, accurate sketching of interior floor plans. These plans are useful for remodeling and restoration projects, property value assessments, and other professional purposes.
Desktop Software
Are you looking for compatibility with a specific type of software, such as AutoCAD, Revit or VectorWorks? Then you’ll want to select a measuring device that supports that type of functionality.
Now let’s jump into the final factor you should consider…
Factor #3: The Specific Features You Want
In Summary
When comparing Bluetooth laser distance measurers, it's important to consider these three key factors: the price you’re willing to spend, the software compatibility you need, and the features you want. By taking all of these factors into consideration, you can make an informed decision and choose the right device that suits your preferences and budget.
View our recommendations for the 3 best Bluetooth laser measuring tools under $200.
See the full list of Bluetooth laser measure devices supported by magicplan.
